My engine problems, why?
Tim,
In the pic the piston end of the rod appears to be twisted. Is that real or an illusion?
I zoomed in as much as I could but there isn't enough resolution to get an opinion of the failure mode. One of the guys on the 951 board is a materials engineer and metallurgist with 30+ years experience with aluminum alloys. He's also a friend and professional colleague. If he had a hi res close up or the actual hardware he might be able help out.
Tim,
I'll get a high res pic and send to you. The rod is bent, but I assumed that happened after the break when it was acting as a jack hammer. The wrist-pin side of the rod does not appear to be bent.
