Question: Threaded Hole in Intake Manifold / Head
As I was checking my oil yesterday I noticed a hole below the intake manifold, between the 2nd and 3rd cylinders, and there is fresh oil around it and the hole itself is threaded, which tells me there should be something there... I ran the engine and worked the throttle and no noises or oil were detected.
Is there in fact something that is supposed to go here? I tried to search, and read something about a sensor, but I wanted to ask the great online community before I took it to the mechanic ($$$). Although he just did my cam tensioners so I wonder if he forgot to replace something, even though it looks like he should not have removed this part of the engine to do that job.
See attached image for reference.
I just checked my coupe and I have an open threaded relief there as well. I had a problem with the crush washer on the oil temp sensor for the head (the plug above the 3rd intake port) and that gave me oil seepage in that area.
Steve
Steve
Thanks again!
Gentleman,
The plug I'm talking about is visible in your pic, it's the black plug right by the cam cover in front of the 3rd runner of the intake ports.
Steve
Steve
