968 Forum 1992-1995
Sponsored by: HBI Auto
968 rear quarter window removal
Old Jun 18, 2008 | 05:41 PM
951rs's Avatar
951rs
Former Vendor
Default 968 rear quarter window removal
Hi all
Mark and I are currently in the process of completely stripping our 968 project car and one of the last items we have not completed yet is the removal of the rear side windows...
Can anybody explain how they are fitted and how you have removed them without damaging?
Will post some pics of the other progress later...
Cheers
Beni
Old Jun 18, 2008 | 05:55 PM
RajDatta's Avatar
RajDatta
Last I remember, they are glued using the same material as the front windshield.
Good luck.
Raj
Old Jun 18, 2008 | 06:21 PM
MichelleJD's Avatar
MichelleJD
Jane Bond 007
Are they the same as the 944? I think you are supposed to put string around the gasket and pull the string and gasket away from the interior of the car while pushing against the glass.
Old Jun 18, 2008 | 08:21 PM
potent951turbo's Avatar
potent951turbo
iPod Tamer
You only need to string when your putting the windows back in. Otherwise just have someone outside the glass to help pull it out and catch it, while you are on the inside pulling the gasket down and out while pushing on the glass carefully.
Not sure on the 968, they might be glued in as already mentioned.
Old Jun 18, 2008 | 08:32 PM
RajDatta's Avatar
RajDatta
Yeah, it definitely looks sealed via some form of glue similar to windshield compound.
Raj
Old Jun 18, 2008 | 09:58 PM
Jfrahm's Avatar
Jfrahm
Easy to do with two people. One gets in the back of the car without shoes on and pushes the window out with his feet. The other catches the window, or tries to. A suction cup, perhaps a toilet plunger, would help.
Old Jun 19, 2008 | 08:39 AM
Julian Allen's Avatar
Julian Allen
Definitely glued in like the windshield and need to be cut out (that is, the urethane glue) with either a bodyshops oscillating cutter or a piano wire.
Old Jun 19, 2008 | 07:39 PM
future's Avatar
future
thanks all for the responce to beni's post ... over the last two days we have completely stripped the shell and today i put the first coats of primer on it and now the car looks great
Tomorrow we will add the top coat in maritime blue so as soon as i get back to the uk i will post all the pictures.
we have also discovered a lot of rust on the underside of the roof which will be getting dealt with in the morning
and yes raj was right the rear side windows are glued in and a real pain in the **** to get out!
cheers
mark
7 Porsche Models That Have Aged Like Fine Wine
Old Jun 24, 2008 | 12:33 PM
rickb20's Avatar
rickb20
Default just teasing us
don't forget to post pictures after it's painted
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
