SteveZ, how abotu sharing some pics of your ride??
#36
Rich, this is the 1st time I have seen this bar. I have seen the CF turbo RS bar before but this is the 1st aluminum "factory" bar.
Looks like you have to cut the vanity cover to make it fit.
Raj
Raj
#38
I did not cut cover when u bought billet aluminium bar it came with a notched cover also the color on the cover is painted Riviera Blue, not inserts.
You gotta find ways to highlight a color you love!![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Rich
Rich
#39
On the Radar
Any update on this?
Perhaps you could take it to Raj's chip test as an aside to measure the results.
It'll be worth the wait . . .
CUSTOMER Damian DeBlis
ADDRESS
DISCRIPTION 968 Porsche Cylinder Head
TOTAL PARTS $2,086.33
TOTAL LABOR $1,837.50
TOTAL SUBLET $850.00
SHIPPING TBD
TAX NONE, SHIPPED OUT OF STATE
GRAND TOTAL $4,773.83
TIME/PN LABOR PARTS SUBLET
CYLINDER HEAD LABOR
DISSASEMBLE HEAD LABOR PACKAGE # 1
REMOVE OIL GALLY CORE PLUGS LABOR PACKAGE # 1
SPRAY WASH HEAD LABOR PACKAGE # 1
BEAD BLAST CHAMBERS & PORTS, SPRAY WASH AFTER LABOR PACKAGE # 1
INSPECT HEAD FOR CRACKS, DAMAGE ETC. LABOR PACKAGE # 1
TOTAL HOURS LABOR PACKAGE # 1 2.5 HRS $262.50
HEAT HEAD, REMOVE 16 VALVE GUIDES LABOR PACKAGE # 3
MEASURE ALL HOLES, DETERMINE BEST GUIDE SIZE LABOR PACKAGE # 3
HEAT HEAD, INSTALL 16 VALVE GUIDES LABOR PACKAGE # 3
ROUGH REEM 16 GUIDES LABOR PACKAGE # 3
FINISH HONE 16 GUIDES LABOR PACKAGE # 3
SPRAY WASH HEAD LABOR PACKAGE # 3
TOTAL HOURS LABOR PACKAGE # 3 2.5 HRS $262.50
FLOW TEST CYLINDER HEAD BEFORE PORT WORK LABOR PACKAGE # 4
PORT INTAKE AND EXHAUST LABOR PACKAGE # 4
SPRAY WASH AFTER LABOR PACKAGE # 4
FLOW TEST CYLINDER HEAD AFTER PORT WORK LABOR PACKAGE # 4
GENERATE REPORT LABOR PACKAGE # 4
TOTAL HOURS LABOR PACKAGE # 4 8 hrs $840.00
MEASURE AND SET INSTALLED SPRING HEIGHTS LABOR PACKAGE # 5
INSTALL 6 OIL GALLY CORE PLUGS LABOR PACKAGE # 5
INSTALL VALVES, SPRINGS SHIMMS ETC. LABOR PACKAGE # 5
TEST FIT CAMS AND TENSIONER LABOR PACKAGE # 5
TOTAL HRS LABOR PACKAGE # 5 4.5 HRS $472.50
CYLINDER HEAD PARTS
16 LIFTERS 928-105-312-02 $683.68
8 INTAKE VALVES, SS PERF. WEN IND. $265.12
8 EXHAUST VALVES, SS PERF. WEN IND. $265.12
8 INTAKE GUIDES CANYON $60.64
8 EXHAUST GUIDES WEN IND. $53.12
16 VALVE STEM SEALS NOK $42.88
ASORTED SPRING SHIMS SBI $32.00
16 VALVE SPRINGS OE "S" TYPE $473.12
3 CAM PLUGS OE $15.18
3 RETAINING BRACKATS OE $14.11
FRONT CAM SEAL OE $8.24
AN WASHERS FOR CAM CAPS MNLY $18.45
NEW ALLEN HADWARE FOR CAM CAPS UBCO $28.35
TIMING CHAIN, HIGH PERFORMANCE DID $38.45
TENSIONER CHAIN GUIDES OE $54.87
OIL GALLEY PLUGS OE $33.00
JME INTAKE CAMSHAFT REGRIND N-??? $425.00
JME EXHAUST CAMSHAFT REGRIND N-??? $425.00
SHIPPING FOR CAM REGRINDS UPS ????
SHIPPING AND DECLARED VALUE UPS ???
ADDRESS
SHIPPING TBD
CYLINDER HEAD LABOR
CYLINDER HEAD PARTS
