Brake Pad Sensors and damper plates?
Hi,
Does anyone know if the damper plates must be used in the rear calipers with organic pads and if the pad sensors must be replaced? Can the pad sensors be defeated by closing the circuit? I'm thinking I won't miss them.
Thanks,
Thanks,
The damper plates (or "anti-squeal" plates) are also never mandatory. Worst case, you'll get brake squeal. Depending on the pad, you may not anyways. If the squeal is bad enough (or even present at all), you could alway re-install them after the fact.
+1. Don't pull out the bulb. You can reuse your old ones if you take them out carefully. I think I even cracked mine but got them to stay in anyway. I don't need a sensor to tell me my pads are low, and, if you can change your own pads, you probably don't either.
Easiest way is to just short circuit them by crimping the two pins. I would never remove a bulb to "fix" a problem. If you work on your car often, you will be on top of pad wear.
Its always nice to have anti-squeal pads but they are not neccessary.
Raj
Raj
On the Radar
Pad sensors are only $16, just replace them and keep everything functioning as it should.
Your breaking system is not a place to save a couple bucks.
I declare, I don't mind the brake pad wear sensors so much, but I've never been a fan of ABS. I'm considering disabling that!
And I wanted to note that I, too, forewent the anti-squeal pads. Guess what? My brakes squeal. And like oil leaks - hate 'em! - I'm ashamed of my brake work on this car because of the squeal. I also pulled the no-no of shaving the pads to fit, so I know I have to re-do the brake job in the near future, probably when I get a set of calipers to properly rebuild and refinish.
Also, these Mintex brake pads are major-league dusters. These babies might have to go out with the bathwater!
At the track, most folks just plug in the sensors but tie them off to something nearby instead of installing them into the pad. The sensors last forever and you are free to put them back into pads at any time you choose.
Just check the pads or you will drive home from the track one day with the rivets of the pad backing plate glowing white hot each time you stop to pay a toll. I still have a cinder of a backing plate remnant nailed to the garage wall with a sign above it that says "don't do this"
I agree that the anti-squeel plates are a must...tried running without them and 100 miles later had them on there because I couldn't stand the noise....my fronts still squeel even with the dampers...but that's because the pads weren't broken in with those rotors...another thing to work on...
Steve
Steve
Just a quick update,
Replaced rear rotors, managed to free up the frozen pistons in the rear calipers, installed new pbr pads (no damper plates,) managed to reinstall whats left of the pad sensors.
All good so far. No squeal, no warning lights so far. Brakes working as they should. Now onto correct the airbag warning light.
Thanks all
Thanks all
Mac, how do you like or hate your PBR's? I absolutely hated them and just swapped back to stock. I didn't like the fact at how little feedback they gave compared to stock. Also, they didn't work as well as stock pads when cold.
I am much happier with stock pads.
Raj
Raj
Raj,
I really haven't had much chance to put miles on them. They are not bedded in yet, so I'll have to report back later. On the off chance that they start squealing after they do bed in, I have ordered the damper plates to put on. I don't have much to compare to, as when I bought the car 2500 miles ago it had pagids with only the outer caliper pistons actually working in the rear. I can say that the pagids that were on the car made huge amounts of dust.
Also strange was during the initial bedding process, I got the ABS to kick-in. Kick-in is a good way to put it as the system comes alive with a violent shudder. Way different than the ABS in my Saab.
