Could my heater control valve be bad?
Well, after finding my bleeder screw underneath the fuel rail I got my system blead but I have no heat. The temp gauge shows everything is okay. Fans are coming on. I did replace the HCV as part of this hose replacement project.
Could still have a air bubble at the heater core, bleeding it with the front end higher then the rear and the heat on usually helps. Or it could be number of other things from the HVAC controls to the HCV. Do you have vacuum at the line for the HCV?
I'll check that, thanks
