Throttle Pedal Height adjustment - heel and toe question
Hi everyone,
I have been trying to heel and toe with my 968, but the throttle pedal is positioned quite a bit below and to the right of the brake pedal. I have very narrow feet and have trouble with it. Are there any ideas of how to adjust OR is there another option out there (like a certain aftermarket throttle pedal)?
Thanks in advance.
rlt
Thanks in advance.
rlt
Have you been trying to heel and toe on the street or the track? If you're having problems on the street you might find that the brake pedal position is just right when you get it on the track. On the track you'll be pushing the pedal harder, and as the brakes heat up to track temperature the brake pedal travel will increase a bit. You might find that this brings the pedals into perfect alignment.
Jim,
Good point, really been trying to do it on the street. I will see how it goes at the track in a couple of weeks. But I will also look into the Rennline pedal too.
