How is your turbo hood different? Is it that the ducts are molded into the hood? Or, is the hood actually lighter and structurally different in some way?
Jason
The ducts are cut in and then molded just like any other ducts. What makes the hood different is the dual latch section that is built into the sides. Besides that, its structurally similar to a standard hood.
Raj
The frame of the hold that supports the contour and runs right by the ducts. Speed6 instructtions say cut, since you have a factory hood I am asking if the factory hood is cut into the supports that run the length of the hood.
