piston squirters
piston squirters
Does anyone have a set of piston squirters left over from a damaged block or even happen to have some spares? TIA
I might have a set from a spare 968 engine let me check tommorow with my machinest? He has the S2 block and the 968 block both spares and he is going to prep one with just the piston walls and crank freshly installed for a later complete 104.5 MM engine. As I recall he was going to probably use the S2 block and find some better squirters, machine the block and install them to shoot oil at the exhaust valve side of the piston.
