battery
battery
Is anyone using a lighter battery or a optima or a gel cell?
Mike
Mike
I plan on relocating my battery with an Odyessey lightweight gel battery. I will mount it in the passenger storage bin.
In my RX7 I mounted that battery in the glove box. They are very small and light weight.
IIRC an Optima redtop is about 36lbs. The Odyssey is 12lbs. Weight Reduction 101
Jason:
Which Odessy?
Which Odessy?
http://www.odysseybatteries.com/battery/pc680mjt.htm
I used the regular (cheaper) PC680 in my RX7 but it's a rarely driven race car. For a daily driver or high end car like the 968 I'd suggest the one I linked to above. More sturdy casing.
Jason:
Where are you going to be on the 11th?
Mike
Mike
Happily Amused
Jason will be at the dyno day
https://rennlist.com/forums/968-forum/363757-dyno-day-anyone.html
Still trying to figure out how to get the time off from the wife.
I would think the Odessey 680 would be a tough choice for a street car...the battery is about the size of a traditional 9-volt battery you use for a toy!
I have a mounting strap that the folks at Paddock Performance fabricated for me.
Jason
Jason
Since I need something "similiar in size" as the OE battery per SCCA racing rules, I read this thread and was ready to go buy an Optima. Then I decide to weigh two batteries I have, an Interstate and a Champion and they both weigh 35lbs on my bathroom scale. The lowest number I've found online for the Optima is 33lbs.
Anyone have any other suggestions for a regular size but lighter weight battery?
It seems you have to watch the height on the 968. The oem size is about 1" shorter than most others. I am trying to find a lighter one that is similar in size as well.
Mike
Mike
