ask the experts...(engine dies - RV)
Can anyone tell me the the range of height on a lowered 968 at the wheel wells.
I am having continued quitting problems with the 968. I am on the track or in the paddock and the car will just quit like you turned the key off. There is no power to the green wire on the coil for ~20 seconds and then the power to the green wire comes back on???????????? I have replaced the dme relay as well as the fuel pump with no change. Any idea here?
Thanks, Mike
Thanks, Mike
Sounds like its heat related. As suggested by Tim, it could be bad joints/soldering on the ECU. The vibrations over the yrs can effect your ECU. I think Rich Glickel had a similar problem with his ECU.
Raj
Raj
I have not replaced the DME. Yes, i do agree it's heat related. The real strange part is power to the coil is gone and then back in 20 seconds. How much is a used DME? Does anyone have the instructions on reading the codes thru the lashing lights?
Mike
Mike
