MO30ing
#31
Crap, Crap, Crap. My front sway bar has almost fallen out again!
This is crazy!
I have replaced everything except the bar itself and the droplinks. Arghhh.
When I asked my mech. he thinks the bar is bent.
I guess I should order that M030 sways from Sunset now.
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
This is crazy!
#32
Dude, just take out the front sway. It isn't necessary for the car to be drivable, and if it's about to fall out, you should take it out before it falls out and makes a mess of things. Our 944 currently has no front sway, since the driver-side inner bracket tore off from the frame rail.
Before jumping on the m030 bars, let me give you another option to ponder: Weltmeister bars. They are way thicker and solid, so they are much stronger than m030 bars. They also come with new mounting brackets which are much more substantial than the standard 968 mounts so some of the flex and play is eliminated there. It might be overkill for a street car. And they are more expensive. Weigh out your application, budget, etc. and good luck whichever way you go.
