Brake Cooling
Jason and Jim,
Are your ducts open or do you guys have ducting(flexible tube) connecting the opening directly to a mounting plate(see pict below) on the spindle/rotor that is just millimeters over the rotor where the other end of the tubing connects? I also have kept the bottom deflectors, but this set-up has obviously not been used yet.
Originally Posted by Jason Judd
Lemming,
WOW!
That is a major crack!
Unusual slotted rotor, too. I've read about them, but can't recall the name. Guess they weren't as good as hoped?
Jason
WOW!
Jason
