LSD
on the road its makes the car fun, on the track it is essential. i had an open diff in my car for the first few track days a few years ago. on a 1m14sec track with the 80%(80%accel,60% decel, clutchtype 4 plate) motorsport LSd i put in i instantly went down to 1m11sec. instead of not being able to put power to the ground and having the inside wheel spinning up a storm, the car is extremly stable on both power and over run at the limit. i would say it was one of the best mods i have done.
and on the 968 we use a 6 plate motorsport LSD.
clutch is the only way to go. torsen only works im one direction, thats acceleration, that means as soon as you get scared going hard through a corner and back off(even a little bit) there is a massive weight transfer to the inside back wheel. well on other word your going to spin.
where as with a proper motorsport clutch LSD if you happen to back off the rear wheels will still be locked which gives you complete control. in my 951 i have had an open diff to start with then i had a
80%accel80%deccel and i finally changed it for a 80/60 and this seems to suit my car and my driving best.
torsens come into their own when doing autoX or motokhana. they power out of turns very well and you can spin the car on the spot when you back off going around a witches hat. good for 180 degree turns etc
sean
sean
Anyone have any clues on how to tell which LSD the '92 968 transaxle diffs have without taking them apart! Because I have a '92 968 with 220 option code that feels like a clutch type when accelerating hard and on decel. But I would like to know for sure, I know the factory kept records but who knows how to really find out, the transaxle code should tell me the build?
There is several well respected sources that have verified that the factory used either ZF or Torsen LSD in 1992 968's. Then somewhere in the 1992 build year they went to only Torsen LSD units, and eleminated the ZF from the option code list!
So who knows how to really tell unless you dissasemble your transaxle?
Originally Posted by Dave in Chicago
I just don't get the "lock up on decel" thing with an ABS car...
Can someone help me understand the benefit? Perhaps I'm just being a bit slow.
With the 2-way or even 1.5-way LSD, both wheels will have equal torque and equal ability to overpower the brakes.
Cars with weak power don't suffer from an open dif, however if you track or if you do something completely ridiculous like a 5.7 LS1 then you need an LSD.
