968 Cab wind stop
Super Moderator
Needs More Cowbell
Needs More Cowbell
968 Cab wind stop
Could anyone please provide any information on how these mount? I haven't been able to find much info/pictures on these.
I've located one and am considering it for my cab if it's a simple install.
Thanks!
Thanks!
I have not installed one, but from reading other posts it is not a difficult install and attaches to mount points already in your 968. I am assuming you are referring to the factory wind stop.
Those that have them seem to really like them. Personally I think the Cab is reasonably quiet with the top down and windows up without it.
it is a "simple" install if all the parts are there
the little round plugs in your rear side panels pop out and are replaced by ones with holes in them - then there are two legs that come down and go in those holes - then you pop the seat backs so the other two legs rest above the latch mechanism - there are also two elastic straps that hook onto the hinges of those seat backs
this all changes if you plan to install my chassis brace/fuzzy dice holder - it get a lot simpler
drop me a line - i can fill you in with more detail
