94 Cab Top won't budge
It was working great and now I can't seem to get it down? I have checked the fuses and they are fine. Is there a relay associated with it? Is there a way to manually get it down?
Pin 6 is the one to bend. Can't remember which relay is for the top without going out to the car and looking (I think it's G21 but double check before doing anything). It should be easy to identify if you still have the chart on the inside of the lid for the fuse box in the engine bay.
Also, with my top I have to give it a little push up and out of the tight down position after unlocking to get the motors to kick in.
Glau
Glau
The relay is G21. It is not necessary to bend the pin. I taped over the pin so that it would not make contact. I believe the relay is fairly expensive so I did not want to risk damaging it by bending the pin.
Here is a UK thread on the topic http://www.porsche968uk.co.uk/phpbb/...9921aba7b2f34f
