Doubt question
Doubt question
I need to remove some AF (I am adding water wetter). Is there an easy fast way to do so without removing hoses?
Thanks, Mike
Thanks, Mike
Thanks, Mike
Thanks, Mike
There is a drain plug screw on the underside of the radiator.
Thanks...I will drain some off tomorrow.
Thanks,
Mike
Thanks,
Mike
Mike,
I assume you need to remove coolant to add water wetter.
Just add it. There is an overflow tube where the extra will be sent once the engine is running.
If you turn that drain screw you are going to have quite a rush of coolant!
Another method would be to remove the hose going from the coolant tank to the radiator. You will lose enough to add the water-vetter but not all your coolant.
Make sure you do bleed the system throughly.
Raj
Raj
