Disappearing oil?
Disappearing oil?
So I have no oil leaks and I don't burn any oil, but somehow, oil keeps magically disappearing. My oil light will come on every few weeks and I check, and sure enough the oil level has gone down. Nothing scary, but it's kinda annoying. Is this normal? This is my first Porsche so I have no frame of reference, especially with the 968.
How much are you driving "every few weeks" and how much are you adding?
The manual says that using 1 liter per 1000 kilometers is acceptable.
Changing the oil yearly / ~ 5000 miles I put in 7 quarts which fills up to the top mark on the dipstick, then a little more than half way through the light will come on at which time I add up to a quart to get back up to the top of the stick.
I am not sure where it goes, it certainly does not drip out the bottom or make smoke out the tail pipe.
Our 968s were designed to loose a little oil.
A Porsche engine, operating properly, will 'consume' oil. As long as the usage stays under the manual's guidelines - 1 quart every 650 miles or so - you are fine. If your consumption increases then you either have a leak or are starting to burn oil (different than consuming) and probably need a compression check followed by some sort of valve/piston/ring repair.
Checking at every gas fill up is a good habit so that you can get a better handle on your exact mileage/consumption rate. At 71,000 miles I am consuming about 1 quart every 1000 or so miles.
Originally Posted by sasilverbullet
I check my oil once a week...good habit to get into.
(kidding, I do check occasionally)
Car has nearly 140K miles on it now, and I go through a quart every 1.5K or so.
Yes, I'm gonna fix the cam cover gasket this weekend...
