Anderson Motorworks Turbo Conversion..
If you are ready to lose your AC, I can find you the link. Its a setup that is built by Speed Force Racing in CA and 9M in UK developed the software. Go to www.speedforceracing.com and check it out.
Raj
Raj
You may want to look through this site before making a decision.
https://rennlist.com/forums/showthre...49805&highligh
this is not the only tale of woes regarding that place
as i said earlier, i get really angry just thinking about it - i drove over 100 miles to take the car to him, spent a bundle, it took forever with delay after delay, he drove my car with a broken balance shaft belt for over 300 miles back and forth to his house, i ended up having to show him how to install the rear swaybar, he installed the wrong balance belt, somehow my brand new 968 waterpump got swapped for a 944 pump, i had to remount the rear wheels because they put them on backwards, the car was an ash-filled mess when i got it back, and i have now had to redo absolutely everything he did
Allrighty then. Sounds like not such a good idea doing business with him. Seems like there would be some takers on a high reliablity low boost interccoled turbo kit for the 968 (while keeping all your accesories) maybe some day!
Originally Posted by Fletcher
any experience with these guys? They make a low pressure set up for 60h.p.
How low of a pressure are we talking here?
3 psi? K24 turbo?
60hp?
Wow, a 60hp increase when turbocharging a 3 liter, 4v per cylinder engine.............
I hope no one pays more than $1500 for this type of HP increase!
Why not go to Home Depot, spend a couple hundred $ on their most powerful leaf-blower, and install it in your 968!!!! I'm sure it will give you at least 40hp (I saw the specs on one, and it claims 1.5 psi @ 650cfm)
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
