under-hood light
Couldn't find this on a search, but can anyone tell me where the switch/sensor it for turning off the under-hood light? Mine stays on all the time now I must have bumped something loose/out of place when working on the belts. Took me awhile to figure out why my battery would go dead after about 14 hours... hard to see that its always on when the hood is shut.
Thanks in advance,
-Brett
Thanks in advance,
-Brett
Hadn't been back for awhile again (boy I hope life returns to normal soon) but wanted to say
"Thank You Raj!"
makes the repair so much easier when you know where to look.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Can't say I think much of the design on the switch holder, pretty easy to slide it up and down under the clip. Problem was that it had somehow gotten pushed too low so it was never being pressed. Then I pushed it too high and the light never came on, then I got it right![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
-Brett
"Thank You Raj!"
-Brett
