Any tips on changing cap and rotor?
Its time to finish up the 60 service before Parade next week.
So far I have
Changed timing and balance belt
new plugs
new clutch, pressure plate and associated bearings
new dme relay
new thermostat
replaced hcv with audi part
rebuilt all four calipers
new pads and rotors
new front wheel bearings
cleaned, repacked and rebooted damaged cv boot
replaced and bled brake / clutch fluid (twice)
changed transaxle fluid
new fuel filter
and other things I have forgotten about
I just ordered the cap and rotor and P221 tool to allow my local shop to align the wheels.
Does anyone have tips or know of anything I should watch out for in changing the cap and rotor?
So far I have
new plugs
new dme relay
new thermostat
new pads and rotors
new fuel filter
pretty simple and straightforward - remember to orient the cap first and then change the wires one at a time to avoid mixing them up - be prepared to have to reach down to grab one of the little screws that you dropped and landed in the belly pan right out of reach
Bruce, nothing should drop anywhere as all the associated hardware is built so that it does not completely remove itself from the cap or rotor. The rotor is held by 3 cheeseheads and you cannot remove them complete and the distributor cap is held on by 3 flat headed screws.
The rest has already been stated.
Good luck.
Good luck.
Location: Albany, CA: celebrating 100 years of independence from Berkeley, CA
Joe, it is AutoZone part number 74671 which is made from dichromated steel. This thread has lots of info https://rennlist.com/forums/showthre...&highlight=hcv
