What Oil Do You Use?
Great news. Seems we have some good choices.
Like I mentioned I'm thinking of changing from Mobil 1 when I take my car out of hibernation next month.
Still not sure if it will be Valvoline VR1 20W-50 or Driven DT 50 15-50.
Will the Valvoline have any effect on my Catalytic Converter? I do need to pass Cali smog.
-Yogii
AKA 968 Novice
-Yogii
AKA 968 Novice
Cliff
The Below is a post I put on Rennlist back in 2017 , you may find interesting in regards to last century Porsche engines & the engine oils that they were built around ( all last century engineering , NOT this century ) }
2017 , big year at Buchanan Automotive , we have never ever put out so much work & on the bigger jobs , the Ripple Effect is still a significant cause
Ripple Effect ? ,what ripple effect I hear you ask
Answer = Very Simple Physics with incredible damaging effects on last century Porsche engines in our climate , or just about any climate for that matter when using completely stupid Low Viscosity, Low Oil Film Strength engine oils( like the stupid use of a this century 5w-40 viscosity) in last century Porsche engines in our climate, its not as bad as it was 10-20 years ago , but its still bad enough & boy oh boy its costly to the owners & its Completely Avoidable & worst still , the use of these so called synthetic Low Viscosity , Low Oil Film Strength 5w-40 & 10W-40 engine oils has had far reaching consequences over the decades , meaning these last century Porsche engines only needed to be on a Low Oil Film strength engine oil for as little as 10,000 - 20,000 Kms to create accelerated internal engine wear & if that engine ( later ) switched back to a decent Oil Film strength 15w-50 or a 20w-50 the internal wear was slowed or even stopped( relative to how fast the wear was ) at that point in time
During 2017 we had multiple ( new to us ) 944 / 951 / 944S2 / 968 Porsche cars where we were preparing for the new owner to do a bit of club track driving & naturally with these cars typically already travelled 200,000 Kms + & some 23 to 35 years old already , we even had a very nice 968 that was low recorded Kms , but with Shocking amount of Valve Guide Wear & excessive con rod bearing wear , the silliest thing would be to take one of these old cars to the track without some basic preparation , because engine life on a race track with a human behind the steering wheel & the "Red Mist" appears ( it usually does ), engines that are worn / fatigued just go bang & its mostly avoidable & naturally ,preparation is not just the engine / engine bay ( fuel /oil /coolant hoses) , but steering & brakes + ball joints checking & or replace
Note } Red Mist is a saying when a driver gets way too excited on a track & goes all out , even though the driver had no intention at all in doing that in the first place (Male humans in cars Verses other Male humans in their cars = Interesting Mix of engines going BANG with old worn engines )
Three Main Areas of concern that we look / rectify before letting out onto the track , particularly if the previous service records show anything other that 15w-50 or 20w-50 engine oils being used previously over the decades , this applies to all 944 variants & naturally the 928 series ( two 944 engines combined ), but generally only if they are going to the track to be punished
Area of Concern 1 }
Twin Cam 944S / 944S2 / 968 ( in many ways they are basically half a 928S/32v / 928S4 / GT/GTS engine ) , yes I know there are lots of small differences , but in basic terms they a pretty much half a 928 quad cam engine & like what we see on the 928 Quad cam engines . The thin single row timing chain between the two cams , this is on the 944S , 944S2 , 968 & the quad cam 928 series , these tiny ,thin single row chains( one per head ) are quite suitable for what there are designed to do & thats simply to drive the Inlet cam by the Exhaust cam & naturally there is going to be a hydraulic ( Oil Pressure Fed) tensioner with its nylon pads putting sufficient out -ward tension on the chain , now this is where the problems start if the engine oil pressure is too low when the oil is HOT & no I am not talking about the track at the moment at all , I am talking about the years of driving , might be to & from work ( normal street deriving ) in the normal thick / heavy Sydney / Melb / Brisbane traffic snarls , engine oil hot & getting hotter ( all very normal ) except for one small detail , this poor 944 twin cam or 928 quad cam engine is on a Low Viscosity , low Oil Film Strength 5w-40 or 10w-40 so called synthetic engine oil during these few years or so , made even worst still in the simple fact that the very very low Oil Pressure at idle has to supply Oil Pressure to the timing chain tensioners at the TOP of the engine , the oil pressure that is already too low is even lower at the top
So what is the concern I hear you ask ?
Answer = The Death Rattle , the engine oil viscosity is so low( 5w-40 is a good contender here ) for the conditions ( mentioned above ) it means that at that normal idle speed ( in traffic ) the oil pressure at the hydraulic tensioner/s is so low the tensioner is no longer tensioning & the poor little timing chain is whipping around on and leading to the cam sprockets on the cams , this death rattle also damages the nylon tensioner guides ( shortens their lives remarkably ) and naturally beat the hell out of this thin single row chain because the engine oil is Low Viscosity & Low Oil Film Strength the metal timing chain is able to cut through the oil film( much lower oil film strength ) and bite into the cam chain "CAST" metal sprockets , causing excessive wear to them , which in turn causes more slack to occur ( metal missing from the teeth )& its a recipe for breakage & break they do and its very nasty ( bent valves , hydraulic tensioner ripped from the head & smashes through the magnesium twin cam cam-cover ( what an expensive mess )& completely avoidable
Note 1 } The" twin cam " camshafts chain sprockets are situated in the middle of the camshaft & are not replaceable separately , they are cast & machined finished with the camshaft( all one piece) , its quite a trick centre drive setup , but expensive if worn & they basically do not wear "IF" that are given every possible chance to survive , meaning good OILPRESSURE hot at idle = 15w-50 or 20w-50 = ( correct chain tension at idle ) & sufficient Oil Film Strength Engine Oil to keep the chain from biting through the oil film & making metal to metal contact
Both Sean & I have heard the death rattle on many occasions ( engine oil hot at idle speed ) , but never when the twin cam 944s/S2/968 or quad cam 928 has been on sufficient oilviscosity for our Australian conditions = 15w-50 or 20w-50 and the basic condition of the timing chains, nylon guides & hydraulic tensioner is in reasonable to good condition
We have lost count how many " New to Us " 928 Quad Cam ( 86-95) , 944 Twin Cam ( 87-95) , 964 911 , 993 911 that had dropped by our workshop ( Mid Summer/hot day ) engine Oil Warning Pressure light Glowing RED , Oil Pressure gauge reading virtually nothing , engine making interestingly bad noises (loose timing chain noises, all at idle ) and all these were on a 5w-40 & even some 10w-40 engine oil viscosities , drained this incompatible oil out of them , changed the oil filter & refilled with 20w-50 & noises dramatically reduced or completely gone & oil pressure warning no longer glowing at idle with that oil temp , but then again is says to use 20w-50 in the owners manual that was printed by Porsche when these cars were new , so its not rocket science
On a 944S , 944 S2 or a 968 ( Twin Cam Engines ) we routinely remove the cams about every130,000 - 150,000 kms & replace the nylon tens pads ( genuine Porsche ) and the timing chain ( Street Car ) but on a more dedicated track & some road driving 944 , then we replace them more often ( cheap insurance ) , removal of the two cams on the 944 series ( 87-95) is much much easier than on a 928 quad cam , access is far better
Area of Concern 2 }
Valve Guide wear , like on a air /oil cooled 911 engine excessive valve guide wear is always a great concern if the said engine is taken to the track & flogged , there is a reasonable chance the engine could drop a valve head , thats because the heat from the valve head is not getting dispersed through the valve guide & into the cylinder head , instead the excessive valve guide wear is trapping the heat in the valve head just enough that at high RPM it will fail & the valve head will just fall off & into the combustion chamber ( Good Night Nurse ). Naturally the bigger the valve head the more it literally weighs & the valve springs closing force is very high & these single cam ( 2 valve heads ) are slightly more prone to it , so be careful with old Porsche engines going to the track for the first time with unknown valve guide wear ( it can catch you out easily )
As I briefly mentioned above , we had a very nice example of a 968 ( manual trans ) at our workshop recently & during repairs & tests , we had the cams out & I removed 4 or 5 of the 8 exhaust valve hydraulic lifters & I had made years ago a special tool were I can easily do a cursory valve guide wear check ( while the cams were off doing the timing chain and slipper guides ) & I was dumbfounded by the amount of( valve stem side ways movement ) valve guide wear , I even took out some of the inlet valve hydraulic lifters & even found one or two inlet valve guides with way way way too much wear ,we removed the cylinder head this 1992 968 engine ( still had its original wax fibre composite graphite head gasket )which was rotted away( good to get rid of that and install a metal custom head gasket ) , but when we had the 16 valves out , the valve guide wear was out of this world ( way way war too excessive for there Kms travelled ) long story to this car , but in a nut shell the valve guides were worn by the previous use of a low viscosity , low oil film strength engine oil , very very common 15 to 20 years ago to use these oils in these cars , but it was all the rage then ( Emperor's New Clothes ), even though the correct answer was in the owners manual printed by Porsche
Remember } There is NO Oil Pressure at the valve guides , its just very very minor splash( more of a weep at best ) & in fact the valve stem seal keeps most of it off the valve guide/valve stem , so the valve stem & valve guide relies on High Oil Film Strength engine oil ( Very Simple Physics ) , so a Low Viscosity , Low Oil Film Strength so called synthetic engine oil can easily turn into high wear for mechanical items in these engines that get No Oil Pressure
Basics Physics Time }
A this century low viscosity engine oil , say a normal street emission compliant 5w-40 ( available to the public off the shelf ) is always going to be lower oil film strength than a last century 20w-50 that has good levels of WWII vintage ZDDP AW packages & then if you compare the same 5w-40 emission compliant engine oil up against a 25w-60 racing oil( we use on track prepared 944 etc ) , then the oil film strength difference is greater still
Oil Pressure } the lower the Oil Viscosity the lower the oil pressure in the same test engine at the same oil temps , so in other words a 5w-40 will give ( Hot ) a lower oil pressurein the same last century Porsche engine than a 20w-50 engine oil ( same engine , same oil temp , same RPM Testing / reference points , Very Basic Physics )
Note 2 } In a last century 944 engine ( all ) last century 928 engine ( all ) last century 911air/oil cooled engine ( all ) , here is the list of engine components that get NO ( NO ) OilPressure & must rely on Oil Film Strength
A ) 944 & 928 ( all ) tall wide pointy cam lobes striking at high speed against the flat hydraulic lifter face , and the lifter/s is held up with two big valve springs ( no valve bounce with this spring tension ), this is whats known as High Wiping Loads ( High Loaded Flat Tappet Design ) , meaning the force applied is wanting to just wipe the oil clean off the lifter face , if the pointy tall cam lobe/s break through the oil film its instant metal to metal , the oil film is the liquid bearing , naturally its this area that ZDDP pressure induced cross linking AW film forms & with the correct Oil Viscosity , from minus 10 deg cel to unlimited high ambient temps = 20w-50 the cams will survive & as mentioned there is No Oil Pressure here at all , just splash
B ) 911 Air/Oil cooled , rocker shafts to cam lobes , same deal , no oil pressure , just a spray of oil in the general direction & the Oil Film Strength has to be high , same goes for the rockers pivoting on their rocker shafts , the lubrication here ZERO , oil film strength only
C ) 944 twin cam , 928 quad cam , 911 air/oil cooled Timing Chains against their Timing Chain Sprockets , , lots of forward and back shockwaves in this area ( opening and closing valves causes the shock waves ) , No Oil Pressure here to protect from excessive metal to metal contact , just slash & Oil Film Strength
D ) Alloy Pistons in their Alloy Cylinder Bores , be it 944 , 928 , 911 , No Oil Pressure here , just splash & Oil Film Strength
E ) Piston small end bearing ( top of con-rod inside piston ) , just splash feed & Oil Film Strength
F ) Piston Rings against cylinders & inside the piston lands , just splash feed & Oil Film Strength
G ) Piston gudgeon pin ( Wrist Pin in USA speak ) moves inside the alloy piston ( 944 , 928 , 911 ) and must be lubricated , no oil pressure , just a bit of splash feed & Oil Film Strength
H ) Crankshaft Thrust Bearing , this stops the crankshaft from moving forward or back in operation & with a manual transmission 944 , 928 , 911 the load from the clutch arm pushing or pulling ( depending on the design ) will transmit massive forces in one direction & if the thrust bearing is having to cope with low oil film strength engine oils there is always going to be issues with the thrust bearing
Note 3 } The crankshaft thrust bearing has grooves / openings through which the engine oil escaping from the adjacent main bearing must must be let through at the same rate as the other engine main bearings , hence the openings / grooves in the working face of the thrust bearing , in my opinion there is no oil pressure at this thrust bearing surface , and it relies on Oil Film Strength , hence why we see ZERO thrust bearing wear on any last century Porsche if its been on a 20w-50 engine oil at all times , but on lesser oil film strength engine oils we see thrust bearing wear , meaning oils like 5w-40 & some 10w-40 etc in our Australian climate , but then again the answer has always been in the owners manual that came with these last century Porsche cars
Note 4 } 928S/S4/GTS Auto Trans version / Front Flex Plate deflected & pushing the bowl shaped flywheel in constantly against the engine thrust bearing , in a nut shell we have seen many of these over the last 15 or so years that the "rear of T Tube" coupling has not been maintained & the single bolt holding it tight has stretched & with the twist of the shaft under acceleration ( shortens the shaft momentarily )& because the front coupling does not loosen as much , the shaft pulls out of the rear coupling and over time you end up with the front flex plate deflected , its not a lot of tension ( you can move the flex plate in with you thumb ) but its a constant inwards tension & with the engine thrust bearing having NO oilpressure to protect it , it has to rely on the Oil Film Strength to protect it & if the oil film strength is low , then bad luck for you , because the engine thrust bearing will wear out & the crankshaft will eventually grind through the thrust bearing & into the crankcase .
BUT we have caught quite a few ( new to us 928S / S4 / GTS 928 Auto ) cars that we have done our T Tube reset & new coupling index bolts & measure the axial play of the crank ( thrust bearing check measurement ) & the ones that are worn ( but not worn out ) we have noted / recored the wear measurement number for that particular 928 , change the engine oil & oil filter to a good quality 20w-50 & then a few years later we go back in to do a T Tube reset & re-measure the wear amount & we have never seen one yet that the wear amount has increased one bit , the wear has completely Stopped , thats because we switched back to a high oil film strength engine oil & looked after the T Tube ( very easy stuff if you know what you are doing )
Remember , the Oil Film Strength varies greatly between most 10w-40 , 5w-40 & even a few 15w-50 in different brands & even great differences between the same brand but different countries
Area of Concern 3 }
In a 944 / 944S / 944S2 / 951 / 968 ( all ) the con-rod bearing journal ( big end bearing ) that will starve of oil pressure at high sustained RPM with normal hot oil temperature with a Low Oil Viscosity ( classic example = 5w-40 ) is journal no 2 & when it starves its all over in a second or two , crankshaft is destroyed & often the con-rod lets go = good night to the engine crankcase & sometimes cylinder head as well ( piston smashes into it , because its now free from constraint )
In a 928, 928S , 928S4 , 928GT, 928GTS ( all ) its con-rod journals no 2 & 6 ( they are on the same crank journal ) and like on a 944 its all over in a few seconds when its at high sustained RPM with the engine oil at normal high temps , the first one we came across was Charles Falzon who destroyed his engine ( on the road ) No 2 & no 6 con-rod bearings staved of oil at high RPM on a famous brand so called synthetic 5w-40 , the so called synthetic side of things did sweet F---k all for that engine ( destroyed / turned to scrap in a second or two ) & since then we have seen a few more , always on a 5w-40 or even a 10w-40
In a air / oil cooled last century 911 > 993 , they will destroy con-rod bearings 2 & 5 , not on the same journals , but in the middle of the crank , same outcome if on the wrong oilviscosity at high sustained RPM & hot operational oil temps with a 5w-40
But Why is it So ?
Answer is quite simple }
The above engines are all road engines & all road engines in last century & this century for that matter have to be functional with BOTH ends of the crankshaft to be used in practical ways , meaning the rear of the crank will need a flywheel , so there is no possible way of doing the Porsche 917 engine thing of having the engine oil pressure feed coming in at that end of the crank( axial feed ) & at the front of the engine we have on road engines pulleys, with a massive bolt in the centre holding the pulleys on that drive fan belts / A/C belts / Power Steer belts etc etc etc , so there is NO possible way of getting engine oil pressure into the front of the crank ( axial feed )
So what are we left with with all of us playing around with ROAD ENGINES , we have to put up with RADIAL feed into the crankshaft to feed oil pressure to the critical con-rod bearings ( big end bearings )
Think about it for a few seconds and it becomes crystal clear ,radial feed on road engines ( 911 , 928 , 944 ) is perfectly fine for most road conditions even at high RPM momentarily , so long as you keep the oil pressure up HIGH ENOUGH to overcome the high spinning speed of the crankshaft throwing the engine oil out ( centrifugal force ) through the very hole the oil is trying to get in to feed the Con Rod bearings along the length crankshaft , its a terrible compromise , but works OK until the Oil Pressure is insufficient & when it is at high RPM , you do not get any warning , its all over in a second or two ( BANG )
Here are some notes written by Hans Mezger ( the designer of quite a few Porsche race engines including the famous 12 cylinder 917 engine }
Because the 911 air/oil cooled engine used for road and competition had Radial feed into the crankshaft to the con-rod bearings , the Oil Pressure needed at 9,000RPM was 70 Lbs Sq " ( 5kp/cm/2) MIN pressure at max racing oil temp
The 908 ( 8 cylinder ) 3.0L air/oil cooled race engine had Radial feed to the con-rod bearings , to overcome con-rod bearing issues in racing the crankshaft required at 9,000RPM was 100 Lbs Sq " ( 7 Kp/cm/2 ) Min oil pressure at Max racing oil temp ( Thats Massive Oil Pressure )
Hence why proper race engines like the 917, 12 cylinder engine had Axial feed & with axial feed there are NO centrifugal forces pushing away the oil trying to get into the crank , so with Axial feed the 917 engine only required at 10,300 RPM was 34Lbs Sq " ( 2.3 Kp/cm/2 ) Oil pressure
So with these last century Porsche road engines we play around with , remember none of them are race engines , yes you can take them to the track , but we need to know why they go BANG & try to avoid it , so obviously we can not turn these into radial feed crank designs ( not going to happen ) , but what we can do is what Porsche did with their 1960's road / race engines , you work with what you have and recognise you need to compensate for the loss of oil pressure going to the con rod bearings ( big ends ) as the crank spins faster & faster ( radial feed has to fight against centrifugal forces ) , its not perfect but we can work with it
Using LOGIC , we know that the lower the oil viscosity , the lower the oil pressure , very single physics & as you can see , last century Porsche road engines need high oil pressuregoing into the crank & thats why over the last 11 years in the PCNSW we have never lost a single 944 , 944S , 944S2 , 951 , 968 engine that compete at the track ( Supersprints ) & we and our customers have won multiple Drivers Championships & Super Sprint championships & Motorkhana Championships , so to let you into a secret we use at the track a Minium Viscosity of 25w-60 Racing oil in all these 944 variants , two of these Porsche's ( 3.0L 951's on E85 ) put out just on 600 HP and they are all wet sump , no acusump & no dry sump & remember all these Porsche's are road & track cars , meaning they all drive to the track & drive home again , they are not dedicated race cars & remember the tracks we compete at do not have some of the very very long sweeping corners that exist at some tracks in other countries , so we can get away with no dry sump in our circumstances , the closets to that is the vary fast corner 1 at Sydney Motor Sport Park , it is a very fast sweeping corner at high RPM , but we have no issues with it
So remember , prepare a last century Porsche engine for the flogging if its going to the track & the beauty of the 944 engines ( like the 928 engines) , is we can remove the engine sump to change the sump gasket & at the same time remove the individual con-rod caps to check the condition & or replace the bearing shells & cap nuts ( all in the car ) , just like on an old Datsun 1600 or Ford escort , Fantastic Design
The Above is MY OPINION in what I have experienced as a independent Porsche Specialist working on Porsche sports cars 6 days a week since 1977 ( getting on 41 years ) & the reason is I am sick & tired of seeing lovely last century Porsche engines being flogged at the track & even on the road on a way too thin this century engine oil & it all ends in tears ( Con Rod Bearings starvation mostly ) & another Porsche engine going to scrap metal ( lost forever ) , I just hope I can save a few last century Porsche engines from this stupid avoidable destruction
And lastly , the above has NOTHING at all to do with this century Porsche engines , meaning Boxster , 996 , 997 etc etc etc ,I am ONLY talking about oil viscosity & Oil Film strength & Oil pressure issues to the 944 ( all ) , 928 ( all ) and air / oil cooled 911 ( all ) road going Porsche cars from deep last century from when 20w-50 engine oils were the norm
Regards
Bruce Buchanan
Buchanan Automotive
Area of Concern 1 }
Area of Concern 2 }
Area of Concern 3 }
But Why is it So ?
Regards
Bruce Buchanan
Buchanan Automotive
Here in socialist Kali smog testing rules are over the top
So, to beat the system and run the proper oil CAT off, wong chip, 20W50 VR1
Every two years CAT back on go get tested, CAT back off and enjoy your Euro P car as she was designed
PM me for my special, top secrete oil guys contact info. He has a connection, usually just for GT car guys in a Members only high level club, but I know a guy. Their oil is rumored to come from deep below the NIle, some say under what was the Garden. Yes, the Garden of Eden. This virgin oil, once extracted has a unique blend of herbs and other ingredients added that clearly support Porsche GT cars demands and thus its 40.00 per litre price
If you can afford a P car this should be the only oil you ever place in your ride
Welcome to the Porsche world of oil choices
Jet951,
Thanks for posting. Lots of very helpful information.
I guess moral of the story is, only use motor oil that is 20- as a minimum.
-Yogii
AKA 968 Novice
-Yogii
AKA 968 Novice
