M030 front struts need rebuild
OP, I have 2 used 030s and 2 NOS that I purchased a few years back but yes, IIRC the last time I inquired Koni no longer rebuilds them and refers you to an “approved” rebuilder. I’m not sure how well that is working. Anyone have any experience with this?
Cliff
No Yogii, not even close buddy. The M030 strut is a different animal. You don’t cut it open and machine it the way you can the standard struts. They are made to be disassembled and rebuilt. Search…
Cliff
Cliff
That is why I am a novice...
-Y
Cliff
Cliff
https://performanceshock.com/
They are one of just a few authorized Koni rebuilders. They aren’t cheap as you would expect. Nor are they fast. It took them nearly a month before a tech could get to them. Mine were in decent shape, just needed new seals and wear items, not even having them repainted. Total just under $800 for the repairs. I believe Porsche still lists new ones available for close to $1500 per side.So $400 per side for a complete overhaul is a “bargain” 😂
Best
Mikey
Thanks Mikey. Yes everything is pricy and this was the range of numbers that I was getting years ago which is why I purchased new ones. I wanted not only a new shock, but I wanted it to also look new. That being said, when you get these NOS shocks, they are ancient the day you take them out of the boxes because they were all built years ago. So that being said, how good are the “new” ones?? And as for the set I received, the threaded sleeves were of a different shade of aluminum. Not a concern to most but to a fanatic… ![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
Cliff
Cliff
Cliff
Cliff
Best
Mikey
Performance Shock will also strip and repaint them on request, for another $200 per side. Threaded sleeves and spring perches are simply raw aluminum, not even clear anodized, so a simple bead blast will have all those pieces the same shade in a jiffy. As for how good the overhauled units are, they use all new production O-rings and Viton seals, the rest of the guts are steel or aluminum, so it’s a brand new shock when you get it back. Good for another 30 yrs and miles of abuse. These guy primarily work on Motons, Ohlins, JRZ, for the race teams. They know their stuff, people are racing multi-millions in equipment so they’d better know it. 🤣🤣
Best
Mikey
Best
Mikey
Mikey
I do not have the Mo30 suspension. However, my car is lowered about an inch, it has the thicker sway bars front and rear. Nearing a 100K my OEM shocks, they are almost done.
Thinking about the Koni, non-m030 option or the Bilstein options. I understand that front OEM Boge shocks are still available but not the rears. Maybe the other way around?
Car rides firm. It is only uncomforatble over rough roads. I do 3 or 4 auto-crosses and maybe one DE day per year. Any suggestions? Right now a coin flip between the Koni's and Bilsteins.
-Yogii
AKA 968 Novice
-Yogii
AKA 968 Novice
-Yogii
AKA 968 Novice
-Yogii
AKA 968 Novice
https://www.paragon-products.com/Por...sion-s/199.htm
Mikey
-Yogii
AKA 968 Novice
-Yogii
AKA 968 Novice
You need to call Jason at Paragon Products in Corpus Christi. He's been supplying and advising on 968 suspensions longer than just about anyone. Yes, he owns one of the 4 968 Turbo RS cars, there's nothing he doesn't know about these cars. A wealth of knowledge, and a helluva nice guy with prices competitive with anyone in the industry.
Mikey
Mikey
Cliff
