Flywheel Timing Mark Picture
I have looked for a good picture of the flywheel timing mark and could not find one. I could not find my timing mark looking through the hole on the flywheel cover plate. I finally removed the cover plate and using my dremel tool removed rust on the flywheel and found the marks. I just wanted to post a picture of what the marks look like for reference if anyone else is looking. They are still hard to see but the middle vertical bar is the TDC mark.
From what i have read there is a sequence of three closely spaced marks that look like III. The center mark of these three is the one you’re looking to line up via the special sighting hole in the clutch cover plate, down low in the bell-housing.
