968 Forum 1992-1995
Sponsored by: HBI Auto
Checking cam timing
Old Jun 5, 2019 | 02:17 AM
  #46
michaelmount123's Avatar
michaelmount123
Originally Posted by Boeing 717
Thanks for the response Michael.
If I already have the engine at top dead center and If put the cams in the same way they came out wouldn't that ensure that nothing would hit?
Also, I can't really turn the crank to get the engine at 45 dbtc because the pistons will be going up and down and the valves won't be moving. Wouldn't that pretty much guarantee that the valves are going to hit the pistons?
(Just saw this...)
If you put the cams in at TDC, two pistons will be up. Your initial cam position will be somewhat close to the correct timed position, but certainly not exact. Therefore, if a valve is open enough to hit the piston, you'll bend that valve when you tighten the cam caps. Note that if #1 is at TDC firing, #4 will be at TDC overlap (valves slightly open). It will be #4 valves that will be most likely to hit.
If you install the cams at around 45 deg. BTDC, no pistons are in range of open valves. At this point you rough adjust the cams like the photo in the manual. Once this is done, turning CW to TDC is safe. Just go slow, and if any resistance is felt, you likely have not pre-positioned the cams properly, so stop, turn the crank CCW to get the pistons out of the way, and re-adjust to match photo.
Old Jun 5, 2019 | 03:43 AM
  #47
ste1999's Avatar
ste1999
Originally Posted by michaelmount123
Yes, fine to go a little past to find TDC. Just be sure to turn slowly and if there's any resistance (valve against piston), stop!
Thanks, this thread has very been helpful so far!
Steve
Old Jun 5, 2019 | 07:27 AM
  #48
jsheiry's Avatar
jsheiry
Jerry
Here are two photos of the factory vario cam wire tool, one beside some home made cam insertion blocks and one next to a home made version of the wire tool.
The blocks are some oak, all thread, spark plug tdc tool (spark plug tdc tool can be bought at any speed shop like Jegs). Made by a guy in MN, think he sold his car and I bought them from him.
John
Old Jun 5, 2019 | 09:59 AM
  #49
Boeing 717's Avatar
Boeing 717
Registered User
(Just saw this...)
Thanks Michael.
Old Jun 5, 2019 | 10:01 AM
  #50
Boeing 717's Avatar
Boeing 717
Registered User
Originally Posted by jsheiry
Jerry
John
Thanks J. I made that wire tool last night. I don't think the coat hangar wire I used is really strong enough.
When you press the Variocam unit down to compress it. How much is it supposed to be compressed? Do you have to push the top piston all the way down?
Old Jun 6, 2019 | 02:40 AM
  #51
Yogii's Avatar
Yogii
You know, that tool looks a lot like the tool for removing the wheel center caps.
-Yogii
Old Jun 6, 2019 | 04:18 AM
  #52
ste1999's Avatar
ste1999
Jerry
John
I’ll bet there are all manner of interesting cam hold down tools out there now for this car. I got a pair of OEM alloy blocks on eBay and was lucky enough to persuade a local aerospace orientated machine shop to turn me some pretty hold downs from 316 stainless offcuts for drinks money. Probably shinier than they need to be.
Steve
Old Jun 10, 2019 | 06:00 PM
  #53
Charlie's Avatar
Charlie
Hey Jerry, how is the video coming?
Old Jun 10, 2019 | 06:05 PM
  #54
Boeing 717's Avatar
Boeing 717
Registered User
It's not. I'm waiting on several parts. Is there anything in particular you want me to film?
Old Jun 10, 2019 | 09:07 PM
  #55
Charlie's Avatar
Charlie
I would like a video on setting the timing. a DIY on timing for the 968.
Old Jun 11, 2019 | 09:23 AM
  #56
Vincent C.'s Avatar
Vincent C.
Default Cam timing
Originally Posted by H.F.B.
The Variocam chain tensioner only works for the correct direction of engine rotation. When I applied enough air pressure the piston went up. There was no up and down when turning the crank. No voltage applied here enables to fill the interior of the chain tensioner that supports the force of the springs. With +12V applied the solenoid forces the piston down.
some info from the Factory Manuals
Old Jun 11, 2019 | 09:25 AM
  #57
Vincent C.'s Avatar
Vincent C.
you must be careful only using one 9248, Porsche says use two 9248 or you can break the camshafts.....cams are brittle if strained the wrong way !!!
Old Jun 11, 2019 | 09:52 AM
  #58
Vincent C.'s Avatar
Vincent C.
Default Cam timing
Here are the last ones that didn’t upload properly
Old Jun 11, 2019 | 10:01 AM
  #59
H.F.B.'s Avatar
H.F.B.
It seems my posting was a bit misleading.
It is clear. I ordered the 9248 Tool, which of course comprises 2 clamps. And only one of the two had a wrong bore, as already posted.
Old Jun 11, 2019 | 10:36 AM
  #60
Vincent C.'s Avatar
Vincent C.
very good....
