For the life of me, I can't get the door handle off...
#46
[QUOTE=WolfeMacleod;15853708 They swelled, and became too thick.[/QUOTE]
Be careful Wolfe...with descriptions like this you could be responsible for 968 owners everywhere causing a run on this aerospace stuff!
Also your excellent video has just been banned for PED's.... The standards committee will be reviewing your next video very carefully for any antics and use of any PED's while performing the procedure. Im officially back on the fence with this tactic being an internet legend.
#47
#48
I redid the swelled seal today Took about 5 minutes. I did give it a good spray of 303 beforehand.
I'm not sure what you mean by "PEDs"
#50
I'll bet a popsicle stick used as a lever, throught the seal, and braced against the metal top of the microswitch would work great. Push the free end of the stick towards the window, stretch the seal just enough to make slipping over the mechanism easy.
Seriously, using this method was stupid easy. So easy in fact, that I'd be willing to do it for local Seattle cars.
#51
Wolfe PED (performance enhancing drug) acronym from sports world. Type PED into the Google machine. Aerospace stuff IE metaphor from sports world.
#52
I removedit about an hour ago. Still not much clearer. As best I can tell, the ball join I need to unclip is done, and has been done for a while, apparently.
However, the handle still will not lift away from the hole in the door.
I have removed the tiny screw on the back of the microswitch, but can't figure out how to remove it from the handle itself.
#55
Another victim here, trying to get the door handle off to replace a broken door handle trigger part number 944.537.672.00.
Late 94 couple with electric locks and M490 HiFi sound (which adds 83742 fasteners and makes every instruction out there on removing door panels incomplete).
I do not see what or where to disconnect to get the handle completely free nor does mine seem to look like all the other diagrams I can find.
I can't see nuthin' through the door panel nor looking in the removed air vent on the edge of the door. Clark's garage et al make it sound like this is a piece of
cake so I either have Frankencar or am just not getting it. Any suggestions appreciated.
thanks
Jon
thanks
Jon
#56
thanks
Jon
thanks
Jon
