Turn signal fast - replaced bulb, swapped relay
As the title states. A while ago, the left front turn signal went out.
I finally got around to replacing the bulb. It now works, but still blinking quickly.
I pulled the relay out of my 924S, since it appears to be the same relay. Swapped. Still blinking fast.
Electrical contacts in the bulb receptacle don't seem to have any corrosion on them.
Any ideas?
Any ideas?
Problem fixed. Apparently I can't figure out how to insert a light bulb properly, and slipped the "nibs" into where they slipped in easiest.... which was wrong.
Simply rotating the bulb more fixed it.
