Tips for installing the most aggravating bolt on the entire car?
Does anybody have any tips, magic tools, etc., for installing the M6 bolt that attaches the dip stick’s bracket to the intake manifold? There’s only a 1-1/4” space between the location of the thread on the manifold and the brake booster, which doesn’t leave enough room for a socket, plus the hard brake line going into the master cylinder is in the way as well. I’ve been fighting with this thing for over an hour, and have dropped the stupid bolt at least five times already. There has to be a way to get this thing on. Any suggestions, preferably ones that have been actually used and proven to work? Thanks.
Ha, I gave up on that bolt a couple years ago.
For street use a zip tie works to secure the tube but you'll need to hold it down with a finger when pulling the dip stick. This probably won't get you through scrutineering thou.
I've had success installing that bolt a few times. Want to say I used a "spring claw retriever" or "magnet on a stick" to hold the threaded section of the bolt in place while turning the bolt head with my other hand... it's been a while and don't quite recall.
Good luck.
Good luck.
I somehow get it done but I know another trick that some have used, they cut open the bottom section of the mounting piece. This way you can pre-install the bolt (leaving some room) and then slide the dipstick on. Finally, tighten the left over threads in the bolt.
Boeing717:
All I can say is, ???!!!!! Or maybe, The reason I need to reattach the dip stick is that I had to reinstall my homemade steering angle sensor, after the string going from the steering shaft to the pulley fell off yet again. This is at least the fifth time I've had to R & R the intake manifold in the process of building that wretched thing (because I was too cheap to pay the $250 for a SAS from Aim), to the point where I can do almost do the job blindfolded. Hopefully I've finally found a robust solution to keeping the string intact. But this stupid bolt kicks my butt each time - it takes me as long to attach it as the whole rest of the job put together, and it hasn't gotten any easier or faster with each R & R.
That's a clever idea I hadn't thought of - thanks.
