Where to buy half shafts
When doing my T Belts I found out that my passenger side half shaft has a cracked boot. I did some searching and found lot of info on where to get them for 944s and Sunset has them for about $250 but does anyone know where I can get good rebuilt half shafts? Or should I go with new, or with rebooting mine and packing with grease? I have only driven the 968 for 4k miles but I do not have any idea how long it has been cracked.
Raj, Thanks for the correction in terminology. Is this something I can do at home on jack stands or something I should go to a shop for? Should I have new boots put on both while I am at it? I know not to get the two sides confused since they are different lengths.
Bruce, its something that is quite simple. You will need triplesquare sockets to remove the cv shafts. I can't see how one can fit in place of the other, so you should be ok about mixing them up.
Change both and you will have peace of mind. Sometimes you can find a local shop that will rebuild cv shafts, take your old one, new cv boots and grease, and new clamps and it should not be more than 2 hrs for them to install them for you and you wont get your hands greasy.
Use the hand brake to hold the wheels in place when removing the bolts.
Good luck. You have my number if you need help.
