968 Forum 1992-1995
Sponsored by: HBI Auto
Coolant hoses
Old Apr 25, 2018 | 09:04 AM
Boeing 717's Avatar
Boeing 717
Registered User
Default Coolant hoses
I have a puddle of coolant on the floor. When I had my car in for motor mounts the mechanic said it looked like I had a coolant hose leaking near the radiator. How difficult and involved a job is it to replace the hoses on this car?
Old Apr 25, 2018 | 03:56 PM
LTCMontana's Avatar
LTCMontana
Veteran: Army
Veteran: Air Force
With the air box and fans out; piece of cake. First, make sure all hose clamps are tight. I found my leak was simply a clamp which had worked loose a little. It was the one right above the fan temp sensor.
Old Apr 25, 2018 | 04:39 PM
Boeing 717's Avatar
Boeing 717
Registered User
Ok thanks LTC. I haven't even looked at the source of the leak yet but just assume the hoses need to be replaced due to age.
Old Apr 25, 2018 | 07:19 PM
chudson's Avatar
chudson
Boeing - you are correct on the age thing although you don't see a lot of postings about hoses failing on our old cars. And don't get fixated on the radiator hoses alone and forget that a 968 has a total of 8 coolant hoses. Porsche is also a bit proud of some of them...
Old Apr 25, 2018 | 08:42 PM
Boeing 717's Avatar
Boeing 717
Registered User
Thanks man, when I have time I'll get in there and check it out. If I don't see a bad hose I probably won't replace them anyway. Just got another toy car and it has all my attention right now.
Old Apr 25, 2018 | 08:43 PM
Nathan J.'s Avatar
Nathan J.
Has anyone used the Lindsey silicone hose kit on their cars, and has an opinion up or down on this kit?
Old May 10, 2018 | 09:38 PM
Yogii's Avatar
Yogii
Anybody?
-Y
