968 Forum 1992-1995
Coolant drain? Where?
Old 03-29-2018, 08:11 AM
thomasmryan
thomasmryan's Avatar
i would pull the radiator and shake it out the temp sender hole or the outlet.
Old 03-29-2018, 06:36 PM
Motosport
Motosport's Avatar
It went all the way in and is lying at the bottom of the end tank. My thinking was also, that it can't move through the cooling matrix and get stuck in the engine or water pump and the direction of water flow will keep it at the bottom of the end tank. But removing the radiator and shake it out through the top inlet sounds like a good idea, except the extra work involved..
Thanks - Alex
Old 03-30-2018, 08:21 AM
thomasmryan
the shard should float. you might try a loose fitting garden hose on the lower radiator inlet and see if it blows out the outlet.
Quick Reply: Coolant drain? Where?
