Anyone want to help me with my flex plate...
btw, with automatics, the ‘rubber damper’ is at the front where a clutch would be...connecting the flywheel to the driveshaft and usually makes a clunking noise when it fails
the 'flex plate' is at the back, connecting the driveshaft to the torque converter and usually makes a ticking noise when it needs attention
does the 968 'tip' have a removable plate on the bellhousing to access the rubber damper like the 968 clutch has??
