Expansion valve?
Registered User
Took my fan box off last night. The expansion Valve has this black sticky stuff on it. Do I just cut it off with a knife before trying to remove this thing?
Also does anyone have part numbers for the 6 screws that hold the base of the AC fan box to the car? I cannot find them.
Rainman
Jerry there might already be a split on the other side, it's just a sort of sticky foam insulation.
If not yes just cut it off carefully with a knife. Later you can reinstall with a zip tie around the foam...BTDT
Registered User
I looked and looked but so far no evidence of dye anywhere. May have to have it checked with an electronic leak checked. But of course that entails putting it all back together and recharging it.
Are these evaporators pretty reliable or are they a common failure point in these cars?
Rainman
I don't think I've ever heard of an evaporator failure in a 944.
Just o-rings dry out, expansion valve gets sticky/clogged with stop-leak stuff, condenser fins mashed/tubes clogged, or hoses develop leaks.
All typical old car AC problems, not 968 specific...really, once you sort it, it will work well![Stick Out Tongue](https://rennlist.com/forums/images/smilies/tongue.gif)
As they say, "keep on keepin on"
Registered User
So far I have new condenser, compressor, drier, high pressure hose.
I took the foam off the expansion valve and there is no dye around that area or any area that I have inspected. Maybe I should not assume the freon has leaked out and check for another reason the compressor isn't coming on. Fuses and relays looked ok.
Have you or anyone else reinstalled that sticky foam around a new expansion valve? That looks like it's going to be difficult to get it on there correctly.
944 572 464 00 are the screws for the lid. 94 on lids are 70 bucks and have the cabin filter option.
variable type valves can trap small bits and its usually pretty audible. the insulation should be air tight to keep the valve from sweating and try to include a bit of the capillary line so its efficient.
personally, i would yank the dash and swap the core. look closely at the loops at the end of the runs especially if it is copper to aluminum....or copper painted to look like aluminum. a dissimilar metal thing. if you do replace it, go with all copper or all aluminum.
Freon...in most forms, tends to deteriorate foam. yours looks stellar so you are probably not leaking gas into the housing. the windshields tend to oil spots above the defrost vents on most of the bad core cars i have fiddled with.
Registered User
Not into pulling the dash right now!!
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
its never fun....the bad housings have the mouses head chopped off in the fan cage. even after disassembly and cleaning, you still get ode-du-carcus smell sometimes
93 and later show a different number on the expansion valve and there is a part number for the black mamby stuff.
I wonder if your interior sensor is giving you off readings
Registered User
Speaking of the later model that has the cabin filter. Couldn't I just get some filter material and attach it to those screens on each end of the housing? Looks like it would be a pretty easy mod.
Rainman
Having pulled the squirrel cage fan off to fix this, you're doing really good. Most often I see people cutting through the plastic to get to the TXV rather than remove the fan.
Will the compressor run if you jumper the low pressure switch?
Registered User
My car is an early model but the TXV is the same shape/style as yours. I re-used the factory foam piece with a ziptie, I wasn't super careful with reinstalling it like thomas suggested, just stuck it back on so it fit.
Back in the day every shop doing A/C work had a bulk roll of this insulation material. I've still got a partial roll of it in my parts room, but with the design of today's cars I can tell you that we haven't needed it in years
