Felgenfuchs.de
The 38 bolt wheels are the earliest RH manufactured and all now are drilled at 40 holes.
Stock size is 52 ET 8" and is 1.25" and 6.75 fronts and rears are 2.25" and 7.75 ET 54 10"
I have seen GMP make 8.5" fronts with 1.75" outer rims, but in the rear 2.25" is the widest that will fit with the Turbo trailing arms but you can increase the inner rim width to make a 10.5" rear wheel. jdorociak@gmail.com
I have a pair of 38 1.25" front outer rims -- and if it were me I would increase the inner rim to 7.25" and then use a 5/6mm spacer to the increased width is split evenly some out some in.
