Safe to run 1.0 bar boost spring?
911 2,
Our cars dont have any ECU. The CO mixture can be adjusted and I would recommend 3-4% CO for mods with CIS.
Maybe someone should post pics of how to adjust the CO??Anybody?
If im right you can only rise the pressure with EFi - with CIS you only have the CO mixture and some guys have adjusted the WUR, duty cycle as well but to be honest EFi would be the way to go- i think soon all CIS will have to be converted if stricter laws come in- which could happen with all this worry about global warming...
As I see that is the same book.
Turning Allen screw left or right is only for idle mixture. Does this CO adjustment affect whole RPM range? I think not. Maybe I am wrong??? Realy don t know.
What do you guys think? Is it better to adjust CO on idle or increase system pressure by adding shims at line pressure regulator, or both?
I read a lot about CO idle adjustment on several Porsche forums, but I have never read something about increasing fuel pressure in the way described above.
Hey now this is something new to me too... I will look into this and see but as said above I really want to ditch it anyway. The parts on our CIS babies are astromical from Porsche anyway just wouldnt make sense if something like the WUR or fuel distr' broke
