Anyone Running Bilstein With Red H&R Lowering Springs?
It's really hard to judge by pictures what is and isn't RS height. The only way to know with certainty is to measure at the specified measuring points. I'm within 1 mm of the RS spec with 1/2 tank of gas and my weight in the drivers seat.The rear looks too high in this picture because the driveway is not level.
That picture is from two years ago. Slate Gray Metallic is one of those 90's colors that looks it's best on an overcast day.
I had it running in November but I had to drop the engine again to install a stronger clutch. That's done but I'm doing some other small jobs while it's out.
It doesn't make much sense to spend so much on a suspension and not do a corner balance.
It should be done anytime there is a ride height change, shock change, spring change.
Before aligning.
Before aligning.
If you track a car that your driving at the absolute limit, I would agree. For the street where your only driving at 6/10th, it's not necessary and possibly a waste of money. The handling limits of a Turbo are so high that they cannot be safely explored on the street.
No spacers. These are the factory speedlines too. I am running a little negative camber all around. Handling is far better than stock. I find the corner balancing made a significant improvement.
Out of the box I find the C2's handled better than the turbo in stock form. The rear trailing arms were not the best design and IMO they would have been better with the narrow body arms on these cars. It took a lot of effort to make my turbo handle shall we say as comfortably as the C2. The turbo did not install the confidence in the turns as the C2 does until I sourced adjustable sways which are very hard to come by for the wide body cars. I have seen some like the white C4 I pictured attempt to use narrow body sways on a wide body which in the case of that car proved to be a huge mistake.
In my case, I prefer to do my own ride height settings and alignments but I don't own scales. I feel that I take a lot more time aligning my car than a shop would and if you rank influence on handling to ride height, alignment and corner balancing on performance, alignment is #1,2, 3 and 4 in importance with corner balancing coming in at #10. Depending on your driving skill, a corner balance could be something you might feel but a bad alignment can even be felt by a novice.
It's like half mooning cylinders and boat tailing main bearing webs as part of an engine rebuild. It's a nice "while your in there" thing to do but might not be all that cost effective.
The PO of my car had H&R coilovers fitted before I bought it. The alignment was incredibly bad. I'll bet it wasn't corner balanced but the real issue was, besides a painful ride due to slammed ride height, was that the car violently pulled to the right when the boost hit. Made the car feel fast but was a little unsettling, to say the least. I traced the problem to the rear alignment; 0 degrees toe at the right rear wheel and + 30 minutes at the left (spec is + 15 minutes per side with a max difference of 10 minutes). Fixing the rear end and raising the ride height to RS spec fixed the issues. The handling limit of a widebody 911 are sufficiently high that I've never had the opportunity to explore them on the street but the car does whatever I ask of it without drama so I'm satisfied.
Got a chance to install the front coilovers today. I have them turned all the way down. It sits 25" from the garage floor to center of the fender. I know it will settle over time.
Still waiting on getting my RH 3.6L wheels back from the shop.
I'm going to try to install the rears next weekend.
I also painted the front calipers.
![](http://i414.photobucket.com/albums/pp227/QuickVR6T/porschesuspensionlower007_zps98589668.jpg)
