Tail light housing
The housing the light assembly sits in is very flimsy metal. I would imagine the bottom of it might be bent and causing the fitment issues. The rear bumper needs to be removed and further inspection needs to be done.
When I get back in July ill look into it and now I'm happy about the car and mechanically I solved the dilemmas it's just this thing now.
Found the issue, I just knew that the new porsche 964 tail lights don't use rubber seals. Removed them and the fit is perfect. My tail lights are brand new ie jan 2013 purchased from suncoast including centre reflector. The previous issue about the bracket light is normal showed the body and paint section of the garage as they re assured it.
I am over the moon happy.
