Jan 12, 2013 | 06:10 PM
I know this is highly contested with lots of opinions, but do these choices make sense?
Engine Oil: Motul X-cess 5W40
Brake/Clutch Fluid: ATE Super Blue DOT 4
Power Steering Fluid: Pentosin CHF 11S
Transaxle: Mobil Delvac 75W90
Thanks!
Matt
Reply 0
Jan 12, 2013 | 06:39 PM
Data sheet has nothing on ZDDP
http://www.motul.com/system/product_...pdf?1302646818
This is avialiable just about every where :
http://www.mobiloil.com/USA-English/...in_20W-50.aspx
and has enough ZDDP
Reply 0
Jan 12, 2013 | 06:50 PM
I would go Mobil 1 or Brad Penn for motor oil. The rest of your list looks fine.
Reply 0
Jan 12, 2013 | 07:11 PM
DO NOT use Delvac. It doesn't play nice with the differential (won't allow the clutch plates to slip like they are supposed to). Use Mobil 90 wt LS gear oil.
Reply 0
Jan 12, 2013 | 07:13 PM
Mobil 1 = not enough ZDDP
Brad Pen has enough ZDDP BUT is not fully synthetic and you risk cooking the oil on the turbo bearing
Reply 0
Jan 12, 2013 | 07:15 PM
Been using Brad Penn for 3 years now and haven't had an issue.
Reply 0
Jan 12, 2013 | 07:19 PM
Have you decided who is going to service your car? Talk to that person to see what they recommend.
Reply 0
Jan 12, 2013 | 09:00 PM
Brad penn does not heighten the risk of oil cooking on the bearing. Who told you that?
Reply 0
Explore
Jan 12, 2013 | 09:06 PM
Quote: I know this is highly contested with lots of opinions, but do these choices make sense?
Thanks!
Matt
Brad penn 20w-50 and don't look back. I've been using it for years in my 993 Turbo which sees a lot of track use. Bearings where perfect when I pulled the engine apart last year. Air cooled cars love that green oil.
Delvac has no friction modifiers and the stock diff will be loud. The diff still works fine but the noise is annoying. Stick with stock and use delvav with a newer diff if you ever upgrade.
For brake fluid just use motul 600
Reply 0
Jan 12, 2013 | 09:26 PM
Hey Black, ever read the spec sheet on Mobil 1 Vtwin 20/50?
Reply 0
Jan 12, 2013 | 09:36 PM
Using Brad Penn 20W-50 on mine..
Reply 0
Jan 12, 2013 | 10:57 PM
Quote: For brake fluid just use motul 600
+1. Better fluid than ATE and doesn't turn the innards of your brake system blue.
Reply 0
Jan 12, 2013 | 11:13 PM
I am going to change the fluids myself, but was trying to avoid the age-old fight over ZDDPs, esters and PAOs. I understand the basics, but definitely don't get into details like the guys on Bobistheoilguy.
I picked the Motul X-Cess because it was recommended in the latest Excellence magazine as a Group V oil. Well, it was actually the X-Max, but that was a stop-gap oil until X-Cess was reformulated (that is my understanding, but there's a lot of WOMs out there!!). I'm not going to use a Group III oil, so Brad Penn is out if it's not Fully Synthetic (i.e. Group IV and V). Was Mobil VTwin an A40 approved oil? I didn't see it on there.
Seems like no complaints on ATE Super Blue.
Same with Pentosin.
Delvac. Yes, I've read the noisy differential reports. Though, my understanding is that the noise is not actually an indication of wear. Whereas, with too many friction modifiers, the gear synchros can become worn. If that is the case, I'm more worried about the synchros. If the noise is unbearable, I'll add some friction modifier. Again, lots of info out there, so any inputs are appreciated!
Reply 0
Jan 13, 2013 | 09:39 AM
Quote: Delvac. Yes, I've read the noisy differential reports. Though, my understanding is that the noise is not actually an indication of wear. Whereas, with too many friction modifiers, the gear synchros can become worn. If that is the case, I'm more worried about the synchros. If the noise is unbearable, I'll add some friction modifier. Again, lots of info out there, so any inputs are appreciated!
I'm not talking about some noise. I'm talking about a lot of noise and since the clutch packs aren't slipping like they should, handling is affected (loads of understeer). I had Delvac in my transaxle for exactly 24 hours and I couldn't get it out fast enough.
As for adding friction modifier to Delvac, that makes no sense at all. You will end up with Mobil 1 LS anyway, except it will be a poorly formulated version of it.
The G50 transaxle has Dana designed syncos, not the weak Porsche designed ones of the 915 series transaxle.
Reply 0
Jan 13, 2013 | 10:42 AM
Quote: I'm not talking about some noise. I'm talking about a lot of noise and since the clutch packs aren't slipping like they should, handling is affected (loads of understeer). I had Delvac in my transaxle for exactly 24 hours and I couldn't get it out fast enough.
Paul,
You've convinced me. I wasn't excited about chatter in a diff to begin with, but serious clunking and handling issues? No Thanks. I see they stock the LS at Advance Auto Parts, is there a better place to buy it? It's $10.99/qt there. Seems like after shipping, the online stores are all about the same.
Thanks!
Matt
Reply 0
