Air screw adjustment
You have to check and/or set the mixture first. If the mixture's too rich or lean, you won't be able to get to the correct rpm.
My car's mixture is set to 14-14.5:1 afr. Then I set the idle speed to 900 rpm.
I guess I may not have been clear. I'm looking for a 'ballpark' setting for the mixture screw, so I can try to start the engine. I'll set the mixture with the meter once I get the engine running, but now the screw's been turned so much I don't know which way to go with it.
