Ground Control Caster/Camber Plates for 964/993 from GMP Performance
Hey Everyone,
We just got ahold of the newest Camber/Caster Plates from Ground Control
These feature more camber adjustment than stock, caster adjustment, and use of aircraft-grade bearings. Every component is anodized or plated, including fasteners. Adds extra travel to avoid excessive bottoming out, this is a very well engineered product.
Camber and caster are adjustable separately by sliding the mounts, without requiring removal of any components from the car. The priority of this design is to allow fast, repeatable alignment changes at the track while still retaining the ability to run the stock springs and spring perch.
Click HERE to purchase or for more info.
