wheel offset (need help)
I need a bit of help. I finally bit the bullet and purchased 4 brand spankin' new Speedlines for my 3.6. I put my Fikse FM10's up for sale, and there is a lot of interest in them from our fellow rennlisters. My problem is that everyone needs the offset info, and I don't have it. I looked at my receipt, and its not on there. Any ideas how to track this down?
Thank you very much for any help.
I did, and Fikse did not put it on there. I called Danny at Fikse and gave him the serial numbers. He is going to go back to the build sheets and let me know. After a few searches, i am pretty sure the offsets are 52 front, and 61 back. He agreed that should be what it is as they are the same size as the stock wheels.
Flip the wheels on their face put a straight edge on rim and measure the distance between rear edge of rim and mounting flange, now you have backset measurement. Backkset- 1/2 of inside bead width will give you offset.
Phil
Phil
