964 3.3 turbo x33 power kit
hi guy,
i have 964 3.3 turbo x33 power kit. i just finish replinishing the engine, but the mechanic make the valve timing setting for 964 3.3 turbo stock.
my question is
1: is theres any problem if i use same valve timing of stock 964 3.3 to x33?
2: if i used this stock valve timming is theres any defferent power on the engine?
3: what is the valve timing setting on x33 factory power kit?
please help me on this matter.
thank you
othman
my question is
thank you
othman
hi guy,
my question is
thank you
othman
my question is
thank you
othman
Hello,
I have too a X33 engine kit, and when I purchased my car from the previus owner, the valve timing was wrong (It was like if it were a normal turbo, non x33). The car behaved badly, it was not fine.
Later, I went to a Porsche specialist, and adjusted the valve timing to a proper numbers (1.2), and...Perfect!!!
Note: the valve timing of the normal camshafts of the turbo is about 0.7 mm.
The valve timing of the x33 option (sc cams) is about 1.1-1.7 mm.
Hope that helps
Gisleno.
Hope that helps
Gisleno.
What I've always read is that if you are looking for good off-the-line performance, go to the high end of the spec.
I've got SC cams in my engine, which I think are what was in the X33 option. When I timed my cams, I set them to 1.6 mm (high end of the spec is 1.7 so I figured 1.6 was close enough). I am happy with the result
