My car is gaining oil?
Changed the oil last winter..no problem. Now it is 97 degrees outside and the oil level gauge and the dip stick both show full when a couple of weeks ago the gauge was showing 1/2 full. Cooler and fan are running. Is there a oil supply pump for the turbo that is not working? Not over heating. Thanks
What's your mixture set at? If you are running very rich, the gas will wash down the cylinders and end up in the crankcase, diluting the oil. Not a good situation as oil dilution will destroy your engine.
Have no idea where the mixture is at but the oil does not smell like gas? I have been just watching the gauge with a hot motor and today with a real hot motor?? The real hot motor has more oil in it.
The engine takes crazy long to fully warm up, especially in winter when its cold. Nothing to worry about. Oil dilution is a problem but you can decrease that. Just hit the autobahn or your local racetrack once a month
In 5 years of owning a 90 C2 I never experienced this. But it had the second oil cooler which I am about to add to this car too. Thanks everyone!
The real test of the oil cooler is what happens when caught in traffic. I owned my car two years until I got caught in traffic and the temp continued to rise to 11 o'clock. If the fan is working it should go no higher than almost 10 o'clock and drop back down to 9 o'clock when the fan comes on.
I had bad fan ballasts on the oil cooler fan and the condenser fan. Replacing the ballasts fixed the problem.
Nothing wrong with my fan and it was not running hot. Just a little over the 1/2 mark. Just in Texas it gets real hot! Better safe than sorry. My old C2 had the RUF cooler and it struggled to even get to the 1/2 mark in the 100 degree heat in traffic....not sure it ever did?
Yep, it was 99 here and that was in a drive through line at the pharmacy. Cooled right down at speed. But with the extra cooler it will run where yours is at. Goes on in 2 weeks.
