Part No request: mudflaps / sill guards
Hi,
My widebody car does not have the item marked below but I'm sure my badly peppered sills would thank me for getting a set so does anyone know what the part number for these is?
Many Thanks.
Jim.
Many Thanks.
Jim.
Hopefully someone will double-check this for me, but I believe you are looking for 965 559 615 00 01C and 965 559 616 00 01C. I put them on my '91 and see why Porsche added them to the 3.6. A must-have.
Kevin
Kevin
They are (or were) closer to $50 ea at Sunset Imports but they're still not cheap. As with most factory parts there is a bit more to them than you initially expect. They have a molded lip that holds them straight and gives a fit that's, well, factory. A flat piece of heavy rubber could be cut to be just as functional but it would lose a bit of fit/finish appeal.
Kevin
Kevin
Does anybody know of a flap/guard which can be attached to the lowest edge of the rear bumper to stop stones being thrown up at following cars or has anyone made their own?
Unfortunately, I have not found anything for the rear and IIRC Sunset price was closer to $57 ea.
I mounted a set on my C2. There is a metal frame inside the flap and it will bend but can be straightened if bent. I ax my C2 and have bent them a couple of times but they do help protect the car.
Anthony,
Sorry, i'm actually looking to fit something behind my rear wheels on the rear bumper as i throw up quite a bit of road debris on some of the roads we use for runs over here and I want to minimise the damage to following cars.
I have the standard guards you've posted, the OP has actually used a picutre of my car in his post.
Thanks anyway.
Thanks anyway.
