Wheel Offset Question - HELP!
#31
I am Running 295 on 10.5 cargraphics in the rear and get a slight rub on the left outer fender under a very hard squat and lots of spin. I am about to go with a 325 on a 12 inch rim with Na control arms I will take some pic's and post when I have finished the install.
I don't know if this help ?
P.s i am not scared of a little rub LOL
David
InyourFaceGauges.com
David
#32
David
David
This is quite a departure from your previous suspension. Paul has done the change over and it is probably something your car will benefit from with all the power you are pumping out.
Would like to see some pics when it is done.
Good Luck.
#34
Not sure I see the benefit of 19" wheels on our cars. Too heavy, won't look right, and probably extra stress on suspension components.
