Dyno at EPL
Just did Dyno day at EPL
Pretty good results with lots of torque .
424.7 AWHP
486.5 Tq @ 4400 rpm
.9 bar boost on 93 pump gas
Stock 3.6 T engine with EFI and small quick spool ITS turbo ,custom intake and Blown six IC .
Car is set up for DE; weighs 2900 lbs with lots of suspension work, so this set up works well . Obviously there is much more power to be had ,but not needed for my use. What i wanted is smooth linear power.The low end torque is really useful for track work. .....street legal and boy is it fun.
These are real numbers on a Mustang . i will let Tony clean up the Haltech map should be even better.
Too bad I'll have to sell this car in the spring I really love it.
Elliot
424.7 AWHP
486.5 Tq @ 4400 rpm
Elliot
Great figures!!,,esp the torque!.
Car looks well cool with the gloss black wheels also!![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Tell us bit more bout that turbo unit you have installed in there if you could??
Stuart
Porsche inspector within UK for Peter Morgan.
http://www.porscheinspections.com/
964 turbo-Rebuilt using ARP hardware.Modified heads,SC cams,1 bar,headers,cat bypass,powerflow air intake..bilstein hd's/h&r,carbon strut brace.Working with unwired tools develope pt model digiwur,although been running with unit for over 6 months,awaiting latest version to post more results.
Stuart
Do you have any build sheet/spec? I am trying to learn as much as I can from those before me. I don't intend to do it 2x.
Things like intake, cams, p/cs, head work, ecu/options, valves/springs, etc.
EFI haltech E'11 v2
55llb low impedance injectors,
ITS custom Turbo 60-2
Stock intake manifold and TB with pat williams rails and injector blocks,
single plug MSD ignition with stock dizzy.
3 inch intake pipe comes up from Turbo inside engine comaprtment w./KN cone
Blown six 965 IC
Ghl headers
B&B exhaust
Tial 46 mm WG
AEM True boost EBC
NGK AF ratio meter
And A/C works !
Elliot
