964 Turbo Forum 1989-1994
Please advice: Maximun RC with CIS
Old 11-23-2008 | 09:05 AM
zarpoxx's Avatar
zarpoxx
Default Please advice: Maximun RC with CIS
Hi rennlisters,
After a while, I am thinking about go further in my mods. I remind you my currents mods964 3.3 turbo)
Sc cams (Option X33 )
K27 HFS (for sell)
1 bar
GSF headers
Cat bypass
LFW
Bypass waste gate
KN air filter
Forge Diverter valve
With the original turbo (K 27 7200) gave 415 hp at the flywheel.
I intend to make deeper changes, but keeping the CIS which I have the following questions:
I would like to improve the off boost mode (performance and response), but I do not know what the RC I must to go (taking into account a maximum pressure of 1 bar blowing, but if you say that is too risky could lower it to 0.7 or 0.8).
You see dangerous operation at 8.5 RC? And a 8.0 RC?
My choices would be:
1. Install only 97 mm pistons of JE Pistons RC 8.0 to 1
2. Install only 97 mm pistons of JE Pistons RC 8.5 to 1
3. Install Mahle pistons and cylinders with 3.4 RC 7.5 to 1 or 8.0 to 1.
4. Install Mahle pistons and cylinders with 3.3 RC 8.0 to 1 ( I don´t know if this option is possible)
What option for you is most advisable? Do you recomend JE pistons? I have read that JE pistons with Mahle cylinders cold make noise (due the different tolerance between materials), but that means I will have problems? They will have durability?
What is the real gains that I could expect from these changes? It is worthy? What is the total amount of horse power that I could expect?
which is the theoretical limit between CIS and RC?
Which is the theoretical limit between RC and 1 bar boost (with CIS)? And with 0.8 bar?
On the other hand, as I will do a complete review, could you say to me what pieces should change (valve springs, ect ...)
Thank you very much in advance
P.D: A picture of my car:
Old 11-23-2008 | 12:28 PM
JamesE's Avatar
JamesE
RIP
I have a set of JE 8:1 97mm pistons with ~3k miles on them. Also perfect bore 97mm cylinders with 3k miles on them, if you are interested.
Old 11-23-2008 | 05:36 PM
turboholic's Avatar
turboholic
hello zarpoxx,
I have very similar specs on my 3,3l, GSF, bypasses cat + WG (love the sound), 1bar, everything except LWFW and K27HFS. Why do you want to sell the HFS? Just curious.
If I were you I wouldnt open the engine if not really necessary (rebuild).
I will try the UTCIS-PT from UnwiredTools (Digi-WUR) to make the CIS a bit more efficient. Surely there are some more horses hiding somewhere...
Sorry no advice on the pistons, but if your engine is still running good without any leaks I wouldnt touch the internals.
Regards,
Joe
Old 11-24-2008 | 08:24 AM
biglicks's Avatar
biglicks
I'd hold off on the digi-wur for the moment, they haven't finished the development for our model. Still a few enquiries may gee them up a bit.
A question for you both, do you have 1bar springs or 1bar pressure readings?
Old 11-24-2008 | 08:51 AM
turboholic's Avatar
turboholic
Hey Steve how is it going?
I have a 0,6bar Tial Spring (large yellow one) and this results in 1 bar of boost with my headers. Unwiredtools is currently working on a updated version of the Digi WUR, I understood that it will be possible to read AFRs, they will maybe even cooperate with Dave from inyourfacegauges regarding this.
Cheers
Old 11-24-2008 | 03:33 PM
biglicks's Avatar
biglicks
Hi Joe, pm'd you.
I've got the 0.5 bar tial and get 0.98bar of boost and it holds al the way to 6500rpm. That's with a standard turbo too.
The problem with the digiwur as I understand it is it can't read our rpm signal correctly so not possible to fuly tune at the minute, athough I think they are working on it, if a little slowly.
Steve
Old 11-25-2008 | 05:31 AM
zarpoxx's Avatar
zarpoxx
Hello,
James E, maybe I could be interested in your pistons, could you send me (via pm if you prefer) the price and any pictures? Thank you.
Turboholic, I want to sell the HFS because I don´t like the power delivery (very linear). It is true that doen´t fall until red line (push like a NA motor, until 7.000 rpm), but It is a litle more laggy. I sell it in 700 euros (has only about 3.000 km). I bought it new from Imagineauto.
Also I would change it into a K27 7200 or one K27 S of similar characteristics (almost new and in mint condition).
Maybe you are correct and I would do not do anything until my engine has several leaks or something like that...
Biglicks, I have 1 bar spring and 1 bar pressure reading. I have the stock waste gate. Do you (to all) think that I should buy the tial 46mm waste gate? What would be the gains?
Regards,
Gisleno Babarro.
Old 11-25-2008 | 07:05 AM
JamesE's Avatar
JamesE
RIP
Will do.
Old 11-25-2008 | 07:33 AM
biglicks's Avatar
biglicks
the gains with changing the wastegate are mostly weight reduction, but also at the age the originals are now they are known to fail and expensive to replace. I went for the version from this site http://www.ssautochrome.com/ much cheaper, although being a copy of the tial some will say it can't possibly be good enough. Mine has been flawless.
Old 11-25-2008 | 01:19 PM
turboholic's Avatar
turboholic
Those wastegates Steve posted are not the original Tial but work perfect. If you want to be on the safe side you can still install a original Tial spring. Now that the weather got colder I have peak readings of 1,1bar but fueling is still rich enough!
Quick Reply: Please advice: Maximun RC with CIS
