964 Turbo Forum 1989-1994
Mini Vmax
Old 12-01-2007, 01:38 PM
  #31
JamesE
RIP
JamesE's Avatar
15 dec is a sat and the only realistic date before xmas.
Old 12-01-2007, 05:21 PM
  #32
nathanUK '81 930 G50
nathanUK '81 930 G50's Avatar
James, will the twisty circuit be available as well?
Does it have walls?
Old 12-01-2007, 06:11 PM
  #33
JamesE
RIP
JamesE's Avatar
We should have access to the whole place, but we will be sharing with others. Exclusive for the day is £7k.
There is a lot of run of, i've span there before and it was fine. They land bloody big planes there so a car is fine, even if you get a little excited.
Old 12-01-2007, 06:27 PM
  #34
graeme36s
graeme36s's Avatar
Originally Posted by JamesE
New rules 98 static at 1 meter.
Hi James,
98db static at one metre. No one will pass the noise test. A bog standard 3.2 Carrera with normal exhaust is 103db. Are you sure that is not drive by. Mind you depends on what rev's that was at 4000 rpm. You need to check this out or you might find it an expensive waste of time. regards, Graeme
Old 12-01-2007, 06:42 PM
  #35
JamesE
RIP
JamesE's Avatar
Mine passes no probs. Turbos with stock exhaust have no probs and I have no cats. They are not to strick so long as no one takes the ****. Turbos are generally a lot quiter than NA cars.
The strict test is 3/4 rpm at 45deg at 1 meter.
As i've said unless you take the **** they are fine, but i do have to tell you the theoretical rules...
Old 12-01-2007, 08:24 PM
  #36
James, how many others will there be?
So those grey areas in the picture are not walls?
TIA
Old 12-02-2007, 04:28 AM
  #37
911addict
911addict's Avatar
Nathan, no walls, just grass. Very wide runway, and only 2 cars at a time.
Old 12-02-2007, 06:57 AM
  #38
JamesE
RIP
JamesE's Avatar
It's about as safe as it gets regarding run off.
Nathan that pic doesn't look like brunters to me.
Old 12-02-2007, 07:56 AM
  #39
JBL930
Not Forgotten
JBL930's Avatar
This is brunters
Old 12-02-2007, 08:12 AM
  #40
JamesE
RIP
JamesE's Avatar
Thats the fellow.
Old 12-02-2007, 03:45 PM
  #41
James, I was under the impression there was a twisty circuit there too? Maybe it is not used?
Old 12-02-2007, 03:50 PM
  #42
See my previous pic?
Old 12-03-2007, 03:19 PM
  #43
Any idea if we will have access to that twisty track James?
Old 12-03-2007, 04:03 PM
  #44
911addict
911addict's Avatar
Nathan,
the whole point of vmax is vmax and drag starts. There are not many curves open to us.
Old 12-05-2007, 12:37 PM
  #45
JBL930
Not Forgotten
JBL930's Avatar
Is the day confirmed James or did you not get enough numbers together??
Quick Reply: Mini Vmax
