looking for brake accumulator bleeder valve,cant find it on accumulator!!
bleeding/changing fluid in my system,,found the brake accumulator on my 1992 964 turbo but cant find the bleeder valve on it,,can anybody tell me where it is or what it looks like????aaaah!!...help!!
Registered User
Are you talking about the cylindrical accumulator in the front trunck behind spare tire????
If so the bleeder valve should come right out of the top of it pointing toward the sky with a black rubber cover on it...
JERRY
JERRY
cheers for responding jerry,,cant see bleed valve/nipple or anything on mine,,mine sits in the front luggage comp near the front panel/bumper..heres a picture below to see if you can point out where it could be!!
![](http://i200.photobucket.com/albums/aa59/stup965/DSC00197.jpg)
That is the pressure pump, not the accumulator. The accumulator is the small ball about the size of a tennis ball. There is a cap and bleeder screw on it. Be careful as that is under high pressure. You bleed it by turning on the key and letting the hydraulic pump pressurize the system and then open the bleed screw with a bleed bottle attached.
