964 Turbo Forum 1989-1994
Oil Line Feeding Turbo
Old 03-16-2007 | 11:04 AM
Frank 993 C4S's Avatar
Frank 993 C4S
Default Oil Line Feeding Turbo
Could someone please post a PET diagram showing the oil line that feeds the turbo. I just discovered a small oil leak where the oil line feeds the turbo (on top of the turbo). To my surprise, there is a rubber hose fastened by a metal hose clamp at that location on my car and it just doesn't look right.
Thanks in advance.
Old 03-16-2007 | 11:23 AM
tjr's Avatar
tjr
I've got the European PET but you can download the US version here - https://techinfo.porsche.com/techinf...e=MainFrameSet
It's under the Engine section - Illustration 107-40 (on the European version anyway)
Old 03-16-2007 | 12:07 PM
fritz k.'s Avatar
fritz k.
hi,
the part-nr. is 964 107 125 20 (for 3.6 engines M64.50) an it looks like this:
Old 03-16-2007 | 08:41 PM
Turbohead's Avatar
Turbohead
The 3.3 turbo oil feed hose is different but stil has rubber connected to metal.
Elliot
Old 03-17-2007 | 07:36 AM
Youcef's Avatar
Youcef
PITA to fit also....bumper off!!
Old 03-18-2007 | 07:57 AM
Frank 993 C4S
Thanks, however the 993 seems to be the oldest 911 you can do this for.
Originally Posted by fritz k.
hi, the part-nr. is 964 107 125 20 (for 3.6 engines M64.50) an it looks like this:
Many thanks for the picture - exactly what I was looking for. Mine definitely doesn't look that that.
Frank
Old 03-18-2007 | 09:10 AM
nathanUK '81 930 G50's Avatar
Frank, I have all the literature. If you need a pic let me know.
Old 03-20-2007 | 11:18 AM
Frank 993 C4S
Thanks Nathan. I have now booked the car in for a service to have the rubber hose and metal clamp replaced with the correct and original part.
Old 03-20-2007 | 12:01 PM
tjr's Avatar
tjr
[QUOTE=Frank 993 C4S]Thanks, however the 993 seems to be the oldest 911 you can do this for.
Strange - I've just looked at this and you can get the parts catalgoue right back to the 356 - look here:
https://techinfo.porsche.com/techinf...e=GenuineParts
Old 03-21-2007 | 09:40 AM
Frank 993 C4S
Many thanks - just figured it out.
Old 06-11-2007 | 08:05 PM
Frank 993 C4S
I would seriously appreciate if someone could please take a picture of the oil line conncetion on the top of the turbo. Here is what mine looks like (don't mind the rust):
I can't figure out how safe this set-up is. I tightened the clamp so th eoil leak is gone. There is a chance that this line had to be re-routed due to my B&B headers. Does anybody have any pictures of theirs? What I am looking for is on the lower left side of your engine compartment.
Many thanks,
Frank
Old 06-11-2007 | 08:12 PM
Frank, remove the clip and look at the tube. If it is plain with no flange then you are correct in it being a hazard. If however the tube has a flared end then this is just the same as a crimped hose except using a jubilee clip instead and is OK.
I have to admit though on my car I took the pipes to a specialist and had new hoses crimped onto them.
Old 06-11-2007 | 09:12 PM
Ag02M5's Avatar
Ag02M5
Many thanks,
Frank
Mine looks MUCH worse. High on my list of replacement parts. Not sure how far up I need to go...i.e. where it is leaking.
RT
Old 06-11-2007 | 11:47 PM
Frank 993 C4S
I removed the clip but I just can't seem to get off the hose no matter how hard I try. The tube definitely has a flange on it.
Old 06-12-2007 | 02:45 PM
Your worries are over then
Quick Reply: Oil Line Feeding Turbo
